H22 swap help
  • Thread starter Thread starter ken2830
  • Replies Replies 1
  • Views Views 896
ken2830
Hey wats up, I need some help, i have these mounts they look just like these for an h22 swap on a EG.
http://cgi.ebay.com/ebaymotors/MOTOR-MOUNT...bayphotohosting
But for the passenger side motor mount they said u have to cut the passenger bracket a little bit and make a new hole for the mount to bolt on, if my car is automatic, would i have to get a manual bracket or can i use my automatic bracket even though they are in different angles??
it may be worth it to sell the ebay ones and get some hasport mounts that come with the bracket that you need. you grind off the welds on the tranny mount bracket and replace it with the new hasport one. also, if you are going to be using the stock intake mani, then it is a good idea to invest in quality mounts as your brake lines are right behind the mani with very little room to spare, and a torn rear mount could mean no brakes.
good luck
cheers
