HELP!!! Grounds
  • Thread starter Thread starter Bwhit12
  • Replies Replies 1
  • Views Views 916
Bwhit12
Got my B16 all dropped in my EG, but it won't start. I have all the important parts hooked up. There is one ground that is not connected which I think is the problem. I have a ground on the head and on the alternator. I do not have the one hooked up that comes out of the wire harness over near the starter. I can not find where it goes. All the bolts are to big to fit in the whole. Someone point me in the right direction I wanna get this thing rollin!!
the main ground is the one you do not have grounded..it grounds your ecu..so it bolts to the thermostat housing..its a 10mm bolt
