Help With Distributor
  • Thread starter Thread starter mbquart911
  • Views Views 646
mbquart911
hey guys------I need some major help with my swap again please!!!!
I am putting a B16A2 head on my LS block. when I got the head it didnt come with any distributor at all......do I need a B16A2 or can I use a GSR or could I use my LS or what....there are some guys around where i live that all have different opinions......
So any extra help would be greatly appriecated.....thanks again
Sean
what yr motor what color distributor plugs, what wiring harness you using. all these are questions i need answered . ls or b16a wiring harness grey plugs 92-95 b16 or integra distributor can be used. earlier yr motor earlier b16 or b18 distributor white plugs. good luck.
also depends on if you are using an obd-1 ecu or obd-2 ecu
