elpayaso201
ok i want to know how much boost can i run on a stock b18a1 ls ? with 114.000 miles on it very good motor. with a t3 turbo
I was going to say the same thing earlier you read my mind!
the tune will pretty much determine what you'll be able to get away with safely.There's a lot more to it than "this motor can run 'x' amount of boost safely" with a lot of it being in the tuning. What kind of engine management are you going to be using? Have you done a compression/leakdown test on the motor to be sure it's in good shape before you add a turbo?
keep it under 10psi and get a good tune. g/l
is this your DD? 10psi should be fine. just figure from 5-10 on stock engine. what kind of "chip" ?
