Som1Dies2Nite
Should I use the B16A intake manifold on the B18B1 or keep the original IM or just use the T/B off the B16A onto the B18? I am running OBD-0.
Originally posted by brian11to1@Jun 7 2005, 07:13 PM
just get a skunk2 unit. you have to modify the water passages to work, i believe
[post=509293]Quoted post[/post]
Originally posted by jdmeg6@Jun 7 2005, 07:24 PM
Are you trying to upgrade the manifold or just using whatever will get you up and running correctly?
[post=509300]Quoted post[/post]
....what?
[post=509400]Quoted post[/post]
Originally posted by jdmeg6+Jun 7 2005, 10:34 PM-->brian11to1@Jun 7 2005, 07:13 PM
....what?
What do you mean by the one on the firewall?
As for better flow, of course the Skunk2 will be better than OEM and will set you back $240 at the minimum
[post=509410]Quoted post[/post]
