map sensor
  • Thread starter Thread starter sbcsam
  • Views Views 849
sbcsam
I just finished installing my b16 in my 95 hb,and i noticed that the engine doesn't have a map sensor. So now i have there wires that i can use for my vtec and knock,or should i look for a throttle body that has a map sensor,or do the b16asir2
don't come with a map sensor
no it didn't come with a map sensor.i used my stock harness and i had an extra plug which is the one for the map sensor.and the harness that can with the b16 dint' have a plug for the map sensor.
B16A's come with MAP's, I'm not guessing, they do. On the top of your throttle body, there is going to be a small metal tube if you had an external, or a hole for an internal.
Here, maybe this will help...
