My ecu came in today.
. I have been putting everything back together today, filling all the fluids, etc. I plan on trying to start it up tomorrow. I have taken a few pics and I will upload them tonight or tomorrow. Dinner time right now then back to work.
Just curious about something. There is a vacuum connection on the top of the IM that is not being used. It use to go to the evap sensor. Should I just close that off?
. I have been putting everything back together today, filling all the fluids, etc. I plan on trying to start it up tomorrow. I have taken a few pics and I will upload them tonight or tomorrow. Dinner time right now then back to work. Just curious about something. There is a vacuum connection on the top of the IM that is not being used. It use to go to the evap sensor. Should I just close that off?
:driver2::w00t:
Intermittent problem maybe. I will check that out and see if any of the wires come up bad, or the sensor. I know the vss not working will keep vtec from engaging. I was looking at the helms and it shows that the vss is ground to one of the pgm-fi grounds. When I test the fuse under dash for pgm-fi I get no voltage, but the fuse is good. Could this be part of the vss problem?
