integra504
Hi, I have a 1995 Integra LS 5spd. I know i can do the ls/vtec but i want to do the b20/vtec for power and also i like the idea. I need help on all the info on what to do in order to complete the swap. I found a block (b20b) and i want to know what head is the best to get. I was thinkin of gettin the head from an integra gsr. I also heard that the b20b is better for turbo, which i want to do, than the b20z. Why is this? If anyone can help me with all the info for the swap, and all the "ways to go" in this swap, I would be gratefull. Thanks
on the swap, it is very informative and will answer any questions YOu have at this point. Also check out the "killer B" article at sportcompactcarweb.com, its all about b series engines and swaps and even goes into 'frank' engines. Despite all this I've told you, I HIGHLY suggest you go with ls/vtec. You already have the engine in your car, and besides if you bore it to 84mm it's the same damn block as b20!!! you'll save lots of money and time if you stick with LS and you can have the same exact results.
