don't waste your $$$ on aftermarket POS. i tried that and their solenoids were pathetically small/underpowered. My friend used PW from a 4dr EF , just switch the bottom rail, and use 2 PASSENGER SIDE solenoid motors cuz dr side will be overused and die out faster. use your stock hardware. Then grab the switches if you want, and drop wires. Should take about same time as alarm install or LEss. . thats from 88-91 model civics. i don't know if 92-95 solenoids will fit.
a jdm power window kit would work too....there nice cause you have the oem controls that fit in crx door panels with some modification...might be alittle bit more money but well worth it
