I had a 1990 crx si with a 1995 b18c1 in it at 290,000 the bottom end gave out
2 years later which is now I rebuilt the motor and put it in a 1991 crx hf
I am using the same engine harness that i used in the si with a ecu jumper from boomslang the resister box is out and all wires tied in using obd1 dizzy and injectors ran good in the si now I go to start and im getting code 16
theres is power at the dizzy on the yellow/grn wire the spark plugs are not firing and the injectors have no power to them I have done double checked every wire on the harness there is a black wire under the dizzy that is black that is missing the end connecter when i skin it back it has a braid wire inside also I do not know where this goes??? also there is a black and a yellow /green wire under the intake manifold I do not know where this goes ???? the fuel pump is working and it has a new main relay there is a sensor on the water neck above the transmission that I have not connected because i cant find the wire to it i think it might be the black single wire that has the braid in it someone please help get my rex back on the street thanks chris
i did the swap on the si with no problems the hf is killing me that it wont start
p72 ecu
p72 ecu
