My speedo jsut stopped working today and shortly after my check light went on. I have no loss in power and my cables are still hooked up. What could b wrong
the wire inside the speedo cable could have broken causing your speedo to stop working. this in turn causes the ecu to throw a code for failed vehicle speed sensor, which is located in the gauge cluster. and it is ran by the speedometer, so if your speedo stopped working then it will throw that code
Why? It is in the wrong place. Please post your topic in the right forums. Hybrid is not for suspension or interior posts. EG is not for EF questions, and so forth.
If you have any questions, please PM the moderator who closed this topic.
