Swap question
  • Thread starter Thread starter mmk21
  • Replies Replies 7
mmk21
I have a 97 dx hatch. I'm putting a obd1 gsr motor in. I'm using my stock dx harness. I have the vtec and knock sensor done.
The only problem i have is the distributor plugs don't match up. Does anybody know which wires to match up so I can splice them. Thanks
you would need a obd1 dizzy, obd1 dizzy plugs from a obd1 harness and a obd2 connector for the dizzy...connect the obd2 connector to the obd1 dizzy plug...all the wires should match up
ok to b sure about the colour /wiring there is a picture on this forum called OBD2 TO OBD1 read
it there is also a picture of the wiiring of both obd1 and obd2
look for obd2 to obd1 (title) its just a couple of topics below yours
I tried that diagram and it didnt work plus I had an extra wire.
If anyone has the wiring diagrams oe can give me the color codes for the distributor off a 97 civic dx non-vtec and a 95 gsrvtec
<span style="font-size:36pt;line-height:100%">
try this
blk/yel 2 blk/yel
org 2 grn
org/blu 2 grn
blu/grn 2 blu
yel/grn 2 yel/grn
wht 2 blk
wht/blu 2 rd
blu/yel 2 wht
don't worry about the extra wire see if it starts</span>
it worked fine for me when i did it
