Phil_Civic
Hey everyone,
I just recently got another Si Hatch, and I want to rebuild and boost the z6 in it. I've done some research but I'm having trouble deciding what's the best way to go.
I'd like to hit 200whp, and spend maybe 3k, including the turbo and rebuild.
From what I've seen, I can run the motor stock and still hit 200whp safely, so I was thinking just new gaskets, bearings, piston rings, oil and water pump, timing belt, clutch and flywheel.
As far as the turbo goes, I'm not totally sure what I should do. Someone locally is selling two T25 turbos off his 300zx. I know they're small, but are they just too tiny to hit my hp goal?
Any ideas and suggestions are appreciated.
Thanks for your help,
Phil
Phil
