http://www.crxpower.net/~silverkorn/manuals/CRX_Workshop_Manual.pdf
memorize every section of that before you consider the swap. As far as your research for the "best" parts are concerned alot of it is simply preference. If you have 5-6k to blow then why not just buy an assembled b18c5 from one of the sites I gave you? They come stock with 195hp or so and if you sleeve it and use some low compression pistons, along with some other little tweaks you should be able to make about 250-280whp without turbo easy
dont worry ill surprise u guy when i come back with alots of the picture of ma civic crx with the engine swap =)...
If you want to make N/A power then you raise the compression, not drop it...
Woot! Woot! Noob alert! Woot! Woot!
h22a = waste of money if your building a tubo motor
rofl thats not what I'm getting at...i know a few deaf people and none of them type like retarded chimps on crack
actually they are some of the best typers i know
You know it bud, so I got the two mixed up, my bad
you guys are a buzz kill lol
Heh heh...just giving you a hard time man...
You're a very good noob actually. You admit your "noobness" and you're willing to learn. Couldn't ask for much more...
OH! today I moved the battery to the back hatch of the crx without burning it down to the ground now I have room for a different engine, tubing, cold air intake, etc...Heh heh...just giving you a hard time man...
oh ah lol am here in the class post on here all day when i get out of school am gunna using a sidekick 2 post on here whatever i want to lol
Your new motto should be "Daveholiday, every post is a potential sig!"
he is b n da engrish class on da sidkik postn in da hs interwebs
