and you did report it... good for you hooligan has reported a post.
Reason:
language and just being stupid and pissed of at something so simple
Reason:
b16b 20+ psi 93 octane gashavn't got your guestion in my inbox? What i was trying to explain about camber is if it changed it will wear the inside if you try to tuck the tire in. MY friend did a lift on his truck with new tires without getting an alignment and his tires lasted a month b/c the camber change weared on the outside of the tires. Any change in camber (other than alignment) will wear tires out quicker. so it would not be a good idea to tuck the wheels by changing
camber. that much camber would hurt handling also b/c the weight of the car would mostly be on the inside of the tire.
It would work but you would be changing out tires alot more often and handling would be diminished.
Did that explain my reasoning?
Need more info about your friends car to be reliable info, like i said in my last post.
What motor, CR, how much boost, what type of fuel, etc.
wow... not once did i say camber doesnt wear tires.. i said its incorrect toe that wears the tire faster than camber would..Yes i did school eg6sir who said that camber cannot wear out tires and whoever else
yeah its scary standing on rache straps to keep the car on the dyno, but as far as this subject goes it really is all in the tune, sure its easier with low compression. but it can be done with high also, just takes the know how and a good tunethose are very impressive numbers on pump gas. I believe you since you sound like you know what your talking about
E.. i'd rep ya but i must spread it first:notworthy2:
lmao i jus realized this is the same guy that wanted to beat my ass awhile back for telling him his answer was incorrect..he threatened B as well
E i actually did suspension tuning every wednesday when i used to race circle.track..so i can be in the same class as you..i feel delighted!!!!
so there ya go hooligan not everyone isnt smart about suspension tuning
i just schooled a hater calling me out saying boosting high CR motors with boost is smart! haha
So are you saying I know my stuff or are you callin me out with this quote? just wondering.
Who's OP?
I think you mean succumbed....this is what honda swap has circum to its pretty pathetic...
i was pretty sure this thread started as LS Vtec Sc Boost and ended with nothing lol.
this is what honda swap has circum to its pretty pathetic over all the past arguments. enough with the nonsensical. lets get with the technical. is that not what this site is for.
~best of luck to you all. and thanks anyway~lou
