K2e2vin
No, J1 only affects the "aftermarket" chip. The area outlined where the chip is usually has nothing. When J1 is jumped, the ECU reverts to the installed chip vs the map already on the ECU. If you take out the chip without disconnecting J1, the engine wouldn't even run since the ECU has no map to read off of.
