which brake fluid...dot??
  • Thread starter Thread starter joker01
  • Replies Replies 6
joker01
trying to find out wa dot code do i use when buying brake fluid dot 1 2 3 4 which one cuz am lost guys
A quick google search says Honda prefers you use dot 3. Just sayin...
"Heavy Duty Brake Fluid DOT 3 08798-9008 4423802 The only brake fluid specifically formulated for use in Honda vehicles. It helps to reduce the corrosive effects of moisture in the fluid and is compatible with synthetic and rubber materials."
i use ATE dot4 racing blue and absolutely love it
and yes brake fluid reservoir cap will have all info you will need, some models it say DOT3 only and some DOT3 or 4
