stuntstere
Well I have a 94 civic ex coupe with the d16z6 with intake, crower stage 2 cam, zex valve springs, and the typical bolt ons; I did a compression test on it and two of my cylinders read 62 and 59 while the other two read 168 and 171.  THe 2 that are low are cylinders number 1 and 3 with number 1 starting by the distributor.  Well I think that I have a couple of bad valves in those cylinders.  My car does not smoke at all and it does not use coolant or oil.  I was wondering if i can use a y8 head with my z6 cam, z6 gear, and springs.  Feel free to give me other suggestions to what might cause those cylinders to be low.  My car has always had idle problems since I bought it and I thought is was the iacv or the screw on the trhottle body but it wasn't.  I have checked my oil and coolant and none of it is missing and I chech my valve lashing too and they are all to spec.  Also I have done all the mods. I bought the car stock.  It has about 190.000 miles on it.
Thanks for all the help
Nick
Nick
