I want to install a Z6 motor and tranny into my 99 DX and was wondering what sort of problem I may have with this. Yes yes I know that I could do a mini me swap but it is way too expencive. By the time I buy a knock sensor, tranny, IM, head, solenoid, a P2P ecu and a upper engine gasket kit I am looking at big bucks. Plus the Z6 is better for a turbo set up so don't try to convince me on doing the mini me swap please.
I know that I will have to buy a conversion harness for my P28 but besides that what else will I need. Is the axles and motor mounts from my Y7 the same as the ones need for the Z6? What about the tranny mounts?
And what about the wiring. I plan on using the Y7 engine harness but I am get the Z6 harness as well. What sort of issue will i run into using a Y7 engine harness on a Z6 engine. I know that there is 2 wire IAC's and 3 wire IAC's. My harness is 3 wire, is the Z6 the same? And the O2 sensor, I know the Z6 only has one but is it a 2 wire or 4 wire? And of couse I will need to run a few wires of the vtec. Is there anything else that I am missing here?
I would really like to talk to someone who has done this swap. I have never done a swap before and thought this would be a good one to wet my feet with. I have a few guys that said they would help me but they have limited experience too and I would like to know what sort of problems I may experience before I start.
Thanks, All Show
Thanks, All Show
this is much simpler, but if your not in a smog state and you already have a z6 motor you can just do what i said.
