93civicracer
Oh, I do a little here and there.
OK..here we go...
the p08 uses a 1 wire o2. you shoulda went with the p28 cause it uses a 4 wire o2. but p08 will work...just use a 1 wire sensor
the TB sensor your talking about,,, is it ON the TB?? cause that would be the TPS sensor... yes you need this. there should be a plug on the harness for it. itll be yellowish(not bright yellow) in color with 3 wires green yellow red.
vaccum lines, they can be TEEed together if theres no spot on the mani for it
hope it helps
Ok..on the 1-wire o2...my original harness has a 4-wire connector for the o2, which I have installed right now (4-wire) so I'll run the d15b7 (p07) ecu for now til I get my car out of the school's shop and can wire vtec on my own time. Then I guess figure out a way to convert it to 1-wire.
Yea the TB sensor is ON the TB and it's weird cuz there's ONE plug that fits it, but it also fits another sensor...so it's on the other sensor for now which I don't know what it is but there's only 1 plug but 2 different sensors (TB and another) that it will fit. It looks like I'll have to route new wires and a new connector to the ecu or something but it's definately missing a plug.
And "TEEed"??? Is that like getting a t-shaped fitting that both hoses can go into but only goes on the motor in 1 spot?
Thanks a lot for your help man I know I'm probably getting annoying by now...but I gotta get this done lol.
