Running rough...wanted some pre-diag thoughts
Discussion in 'HYBRID -> EG-EK / DC' started by UNDR8D, Mar 20, 2009.
  1. UNDR8D
    UNDR8D ...has a job!
    8OH!5
    So my car is running like dog shit and before I tear it apart I wanted some feedback. I recently did two things: put Sea Foam in my oil (eeek) and pressure washed my underhood...both within about an hour of each other. Now, it runs great for about 8 minutes until it warms up then it runs on 2 or 3 cylinders at low rpms. After 3500ish the 3rd cylinder kicks in and the 4th around 4200. Otherwise it sounds and smells like a chainsaw.I'm thinking I fouled the plugs with water or the Sea Foam. Oh and ftr car is a '95 EG w\ LS swap...nothing else special...I'm at work on my phone trying to post this so forgive my breavity.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yeah its something with the spark or injectors for sure. im thinking water got to it somewhere
  3. UNDR8D
    8OH!5
    I agree. I thought it would have dried by now though. All this happened last Sunday...
  4. UNDR8D
    8OH!5
    So, 1 can of wire dryer, four NGK platinums, a packet of anti-seize and a packet of di-electric grease and everything is fine. I pulled the old plugs last night and they were all wet. There was a good amount of water in the plug tubes as suspected...
  5. AHHVTEC
    Alabama
    yeah get all that out of there real good and replace with new
  6. labe lincoln
    labe lincoln New Member
    atlanta, ga
    kinda sounds like a blown head gasket. when you washed it the water should evaporate soon enough and be fine. you could have fouled a plug though. replace them. how bad were you leaking oil.
  7. www.Head-Mechanics.co.uk
    www.Head-Mechanics.co.uk New Member
    Once a spark plug gets water ingress it is usually damaged even if dried out. I repair head gaskets for a living and this happens alot.
    I would get compreed ait on all electrical contacts and replace plugs. injectors should dry if you blast the water. It fires when you rev it as the compression is raised and the small spark is enough to ignite the mixture at idle the spark isnt powerfull enough.
  8. UNDR8D
    8OH!5
    thanks for the info...the issue has been resolved. as stated it was the plugs
  9. TurboMirage
  10. UNDR8D
    8OH!5
    Ya fo sho...I was hoping it would explode on the way home so I'd have an excuse to buy the Volvo wagon I've wanted for so long...
