daveholiday
Do work
Then I guess you'll just have to make a call and see if they have any, you need them.
ive done this 5 times atleast.....the damn thing will not stay in one place...i got the z6 head.z6 gasket,z6 cam,z6 camgear.z6 timing belt...i need someone to help me in person..maybe im doing something wrongSet the crank and the cam both to TDC and just put the belt back on like you were installing a new one. Once you have the belt on turn the engine through a couple of revolutions and set the crank back to TDC. If the cam gear is still in the correct position then you're good to go.
ok soo im going with th three marks on the crank..now i set those then loosen the tensioner...put the belt on with all the slack on the riht side of the motor(towards tensioner side...i then tighten the tensioner..roate the motor to the left(front of the car) soo the cam turns 3 teeth??You need to make sure there is no slack on the side of the belt that goes directly from the cam to the crank, and have all the slack on the tensioner side. Also don't go off the mark you made anymore because it will not line up if the belt moved.
thanx for the help...ive been using the manual but it doesnt get me anywhere...i need shit explained to me directly..i dont learn buy reading out of a book..the head isnt damaged weve looked... just dont think im doing the timing correct thats allyou never said whether or not you found the second dowel pin... without it your head might slide around slightly despite the tightness of your torque, and it will especially move around potentially BEFORE you tightened the head bolts.
fyi i did a head gasket twice in two days (first time failed) and before the second time i did a lot of research... turns out honda recommends a different gasket and head bolts IF you have blown your gasket before. even the torque sequence was more 'cautious' or thorough than what my manual said. but, this was a d16a6. just saying this might be the case for your setup.
i feel for your frustration man... but if you are going to do this type of work on a car you have to learn how to do it correctly. all of your problems with timing belt, timing issues and blown head gasket are indications that you are rushing parts of the process.
i am also concerned that maybe you damaged the head when you tried to start the car with the timing out 180 degrees as you posted. dave holiday and others are trying to tell you over and over to read your manual and get the timing correct. this is so essential.
all in all... i really hope this car ends up running for you. we can all see that you are mechanically inclined and your effort should be rewarded. best wishes...
correct me if im wrong
ok soo i use the one line that is to the right of the three lines on the pulley??and then when i do ignition timing i use the middle of the three lines that are to the left of the single line?!?and i followed what you told me and i think it might actually work..now i just have to redo the crank pulley...Holy crap. I hope the rest of the newbies reading this topic get one point. Find out what you're doing before you start the project. This should have taken three days, at the most.
Your head gasket will very likely blow again because you failed to keep your parts organized and sprayed the copper spray before you were ready.
You're supposed to use the TDC mark on the crank pulley, not the marks for the timing light. That's your first problem. Your second problem is that you're not putting proper tension on the timing belt, per the manual. Do the job correctly and the engine will run correctly.
well my brother just tossed me the keys...hes giving it to me for $500...soo i really need to get this figured out
