The Hasport one. It will allow you to keep all of your pedal system the same, cable the same, and will be the easiest to install (and cheapest).
I will warn you, though. The Hasport kit (or ANY conversion kit, Hasport being the best) will make your clutch feel wayyy different. It won't feel as normal as an actual cable trans.
I would do exactly as Blanco said. Pick up an EF Si cable trans. It will feel a lot better in not only clutch feel, but also the gearing is VERY fun!
With the Innovation kit, you will need to buy a lot more equipment to get the car going. Not only will you have to run a new hydraulic line from the master cylinder to the slave cyl, you have to INSTALL a slave cylinder (if the trans doesn't already have one on it), and you'll need to go through the hassle of rigging your pedal assembly, and I can assure you that being on your back underneath your dash for any extended period of time SUCKS BALLS.
Go with the Si transmission($<200 and you have a spare tranny around to sell).
If you absolutely do not want to do that, go with the Hasport Conversion ($250 and have sloppy pedal feel).
-Andrew
