yes i did, i even went to oem honda wed site, but still not sure how to fix it. That's y if some1 can post of there h22a accord engine photos, that will make it clear where all the hoses and parts connect to.
i already went to those sites, i already did the swap few years ago, my car runs, but i just want to make it run it the right way, but thanks for helping
there's 1 more thing i need to know, for h22a in 90-93 accord owner, there's a BIG BLACK BOX on top of the EVAP CONTORL CANISTER, do i still need it after the swap?? and what is that box for??
Sorry that I wasn't much help my friend. Best of luck though. Let us know how it all turns out.
EDIT: Suggestion, why not take it to a tuner shop? They will know what to do with such an engine swap. I see that you are in Florida and if you are in Orlando, try Central Florida Turbo. There's another one but I can't think of the name right now.
im sick of not being able to find wiring on 90-93 accord external to jdm internal h22a coil wiring... mine runs fine whatever i did to it by splicing into a yellow wire and some blue wire. not sure what else to do it has trouble starting when its cold but starts fine when warm. i cut the black and white wire from the larger grouping of wires coming out of dizzy not sure if anything needs grounded since i went from EXTERNAL TO INTERNAL!
