Better head for boost?
  • Thread starter Thread starter FLounder
  • Replies Replies 11
  • Views Views 2K
FLounder
power hungry
VIP
so there are some conflicting opinions i have heard on this.... which head is better for forced induction.... GSR or b16a??
The B16 flows better, but the GSR cams are better than the B16s, so a B16 with GSR cams is about the best budget boost option.
+1
heard a dude driving a camaro tell me "theres no replacement for displacement" but I waxed him in a 1.8 soo yea
if your on a budget a b16 head and some gsr cams would run you like 300 bucks, if you buy them used...
cant wait to see a build thread
well i have a b16a head already... someone wants to trade me a gsr head though, so im thinking about it. both have original cams.
Actually neither flows better. The chamber shape is what makes one handle boost better than the other, and that would be the GSR.
EDIT: Theres a flow chart on www.b20vtec.com with both heads on it. Theyre almost identical. For one reason or anotehr I cant post the chart from work. :shrug2:
The gsr head has something called quelch pads. These do something to help ward off detonation. I have read this from a couple of different sources, but am not sure exactly what they are.
B16s are pent roof too, as are most modern Honda engines. Quench pads only work if the pistons are designed to work with them.
I'd choose the B16A head simply because there's more intake manifold options.
Nope, all pent-roof. The crease may not be noticeable, but they're all pent-roof design.
Here's a pic from Endyn where you can see it well:
