they are 15x7 +42 offset. do you know much about fuel cell regulations? ive been trying to get answers on a remote fill for a fuel cell in a hatch and ive gotten mixed answers on what is legal and what isnt.
What kit is that you're using? Did you piece it together yourself? If so, which caliper and which rotors are you using? I've been trying to find a kit that fits under a 15x7.
Fuel cells are in section 15.4. A fuel cell is too much work with the newer rules, I would use the stock tank or put one back if you already removed it.
•There must be a solid metal bulkhead completely separating the fuel tank, fuel
pump, fuel cell, filler neck hoses, and/or vent lines, from the driver compartment.
• The cell must contain a bladder that is FIA FT-3 (or higher) rated.
• The cell should be in a container made of at least 0.036-inch steel, 0.059-inch
aluminum, or 0.125-inch Marlex, fully surrounding the bladder.
• Foam internal baffling is required, as per FIA FT3-1999 (or higher).
• The filler cap, line, vents hoses, etc. should be designed so that no fuel will
escape if the car is partially or totally inverted.
• There should be a small drain hole in the outside box to purge fuel trapped
between the bladder and the box.
• Filler necks should not be mounted through a window panel (exceptions may be
made at the discretion of the Chief Scrutineer).
• The competitor is responsible for ensuring that the cell, bladder, and components
are installed, maintained, and replaced per the manufacturer’s instructions and in
accordance with applicable sections of the CCR.
• The bladder has a date of manufacture and serial number. The competitor is
responsible to note this in the front of the logbook.
• Bladders older than 5 years should not be used, no exceptions.
• As a January 1, 2009 the competitor will be responsible for showing proof of the
age of the bladder. It is highly recommended that the receipt for the purchase of
the bladder (or entire cell) be stored with the Vehicle Logbook.
http://www.google.com/url?sa=t&sour...ywy3xDVOjiBB89CwA&sig2=tPQ3QiKcdduiBVAAbCHWsg
