Add some tire presure. Ppl always say drop your pressure cuz they dont understand that with a stiff sidewall street tire, droping pressure doesnt work like it does with slicks. Inflate your tires to the full recomended pressure, and drop it from there. I bet youll notice a drop in your 60fts before you get to 25 psi, and a gain after you start gettin lower than 25. Always make sure the tire pressures are the same from side to side. Also, a 2 second 60ft on street tires is pretty damn good for a FWD car.
The best way to spool your turbo in the lights is to get a 2 step. Theyre cheap and do just what you want. But, like it was already said, if your havin traction problems now theres no need to be spooled on the launch.
