No it wont, not even close. Some stage 2 or 3 cams and valve spring upgrade, skunk2 intake mani, you should already have IHE and tuning will get you over the TypeR's 197hp, that hp at the crack not the wheels. I gain close to 25 whp on my B18b with just IHE and tuning, a stock B18b puts down 142hp at the crank im making 160 at the crank and spent less than $800 most of which was the Hondata. If you buy smart you can get parts cheap.to make a gsr have the same output as the type r will cost you more than 1k. get the type r but just know that the axles that come with it wont fit your current setup, you will need to get integra axles.
Yep B18's all of them need to have these from a 99-00 Si if swapping into a 92-00 Civic. If your Hx is already a manual trans then great that helps a lot. Swap the trans mount bracket from the D16 to the B trans, uses all the Civic's rubber mounts or upgrade to Hasport. The Hx harness will not work either. When I did my B18b swap on my 98 HX I used a 98 LX harness. The HX has an EGR and 5 wire O2 that makes rewiring a huge pain. Get a 97 EX harness and check out FF-squad.com for any wiring and repinning, it will be minimal and easy.your gonna need the 99-00 si rear bracket and also your gonna need the timing belt bracket.
