1965 C10 k4a2 swap.
The Judas Goat
As the title says, I've got a 1965 C10. It's a pretty original truck, but I'm extremely bored, and it's got a 230 motor that gets 10mpg with almost no power. 2 years ago, I purchased a 3.9l cummins and rebuilt it to use as a powerplant for it, but after fixing up a K5 Blazer with a diesel, I don't want another diesel.
So, I'm going to sell my 4bt motor/nv4500/accessories and buy a motor out of a TSX and turbo it. I found you can basically buy adapter plates to mate to any rwd transmission. Everywhere I read said the TSX k24 is the way to go and an S2000 transmission is the match for it. However, I may go with an NV3500 or an RX8 transmission. Whichever I can find at the pull apart first.
The issue I'm running into is finding the best stand alone ECU harness. Most appear designed to fit in specific models. I really want a good universal one.
Also, I plan on turboing the motor, and am looking for a good medium priced kit.
I can weld my own mount brackets, but I'm not quite sure what other parts I should be planning on purchasing. Does anyone have any suggestions?
The Judas Goat
Honestly? They are just as available as the LS motors and lighter and cheaper. Plus, with the right block, I can supe it up relatively inexpensive. Also, nobody has done it, and I like the idea of people's disgust when they see what's under the hood. I have to keep the truck for life, as it's a family vehicle, so resell value means nothing to me.
