2014 Veloster Turbo
Replacement oil cooler is in looks like I will be doing radiator hoses soon too.
i guess i will eventually fix the oil cooler and radiator hoses, i have em all.
also bought new tires and spark plugs.
Back suspension swapped but fuck me this thing goes through front konis like a high schooler goes through vapes. Over 200 each corner, more economical to buy a coilover. I stiffened up the rear shocks and I’m going to run the stocks stuff up front again. I’m done.
finally addressed the oil leak. Wish I could do the radiator hoses at the same time because a gallon of coolant came out. They are tough to find the set I ordered from a retailer online hasn’t even sent any correspondence or taken my call in the last week.
Anyways the hoses are the real PITA here, having a longer angled needle nose plier would work best for them. The nut is 30mm torqued to 41lbft and some loctite.
New sa2020 helmet. It feels cheap compared to my old racers choice which expired for sanctioned scca events.
also got the 225/45r17 Azenis rt660 mounted. 10 days until showtime!
The season has begun.
Day 1 at lrp for Gorman performance summer shakedown.
Plugs and air filter in the Jetta. 110k
Neat photo of the veloster at the bar last night. Kristen and I saw a cool band.
Well still leaking fluid I happened to be all over the car checking everything and found this fantastic bullshit. I ordered new oem lines for under 200 shipped they go from the lower firewall to each wheel/soft line. This was at the rear aero panel by the gas tank. Ugh all 3 of my Korean cars now have rotted rear brake hard lines. So much crap on this panel too safe to say it isn’t going back on. I will probably break most of the bolts and clips anyways.
