Connection questions 2
He was actually posting for me since I couldn't do it from my shop and the descriptions never made it to his email for some unknown reason. My apologies.
Pic1 Wondering what vacuum line goes to the connector just behind the throttle body
Pic2 MAP sensor on the firewall, wires are no where near long enough to go to the throttle body, should i extend them so they do?
Pic3 The wiring that plugs into the fan, Where does the short red one wire plug go to?
Pic4 four vacuum lines coming from the evap area, they are labeled but only one reads clear. Throttle body, Left something, right something, and unreadable
Pic5 Line on top of the Throttle body, i believe the red hose connects here
Pic6 Picture of the red hose I talked about in pic5 as well as the origin of the unknown vacuum lines
Pic7 Capped part of the engine harness on the driver side of the car
Pic8 Picture with the cap out, does anything go here?
Pic9 Module located in the drivers side corner of the engine bay with nothing connected to it, do i have to worry about it?
Pic10 Sensor on the rear of the transmission passenger side, unsure wether this is backup lights or vss.
Pic11 Sensor on the front of the transmission passenger side, also unsure wether this is backup lights or vss.
