im going to be swapping a b16 into an 88 dx here is what i gathered so far some people say you need the hasport mounts so it doesn't hit the hood but some say you can use the regular mounts and cut part of the frame out of the hood and it will fit or you can't use the regular mounts at all, so wich of the three is right? next some people say you have to buy the subharness from hasport for what i don't know (vtec mabey) but i also heard you can use the regular harness and the b16 ecu and just add three or four wires for vtec (vtec solenoid,vtec pressure switch,knock sensor) who is right i would really appreciate it if someone who has done this before or knows all about this to guide me in the right direction.
