GlassHeadlights
West West Yall
Just so I got this straight....
You need...
-Complete Engine
-Swap Mounts
-Transmission
-ECU (in my case, a new chip)
-Wiring Harness
-DA Integra Axles
-DA Integra Drivers Side Mount
-DA Integra Rear Mount
-Shift Linkage
You need to do...
-Hammer in frame by the "square"
-Bolt in engine
-Make wiring harness
-Hook up all hoses ect.
-Remove dust caps for Integra axles
-Cut shift linkages/weld togther (I am too cheap )
And what do you do about the exhaust? Does it match up? How about the throttle cable?
Simplest B16A swap for a EF looks to be a Integra XSi engine because it already has the driver and rear side mounts plus it has the proper axles. This one comes with everything except for swap mounts. I have a OBD1 conversion and a OBD1 ECU.
http://hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30003
You need...
-Complete Engine
-Swap Mounts
-Transmission
-Wiring Harness
-DA Integra Axles
-Shift Linkage
You need to do...
-Bolt in engine
