B16a2 Turbo Size
JDcompman
Ok, this is what I'm building have. B16a2 with b16a2 head and b18c1 tranny. Honed cylinders and ross racing pistons with cr of 9.0, Hondata on a p28. This is all going in a 94 civic dx. Please let me know if you need ne more info but i would really like to know what turbo size to get for this engine/car. I wanna run between 10 and 20psi if possible. Thanks <_<
What is your power goal? I dont see stock sleeves holding 20psi from a decent turbo very long. 1000$ USD for new sleeves installed by Golden Eagle Manf.
IMO.. i think acouple of good turbos for the b16a2 is the t3/60-1 and the t3/t4. If its more of a track car, a t4/60-1 wouldnt be a bad choice. I dont know much on turbo's, but t3/t4 is most common b/c its became a "fad"..
What is your goal for power? What kind of use will this car see? Autox or drag?
Id go with a t3/t04e, 57 trim, .63 turbine. they can be found at cheapturbo.com for around 550...if you dont mind a little more lag but more power potential, there is always the 60-1 :)
turbonetics turbos are 2002.
hello and welcome to 2003 :)
http://precisionte.com
SC50-425hp
SC32-480hp
SC34-545hp
SC44-565hp
SC60-580hp
SC51-585hp
SC52-600hp
SC53-610hp
SC54-620hp
