I believe I have. All my wire colors match up and none of my wires are protected like factory.Why dont you just test them to see if there is an open somewhere before redoing everything. Have you ruled everything else out?
If factory harness' had shielded wires, then re-do and shield wires. Wether that's the problem now or not it should be corrected - if you plan on a music system it could cause lots of havoc there too.
Back to the build, the green wire form the TPS and the green wire from the the temp sensor on the front of the head are connected together in the factory harness. I assume the green wires are grounds? The IAT sensor has a green wire as well and there are no left over wires on my engine harness so I assumed it was a ground too. Is that correct?
