K so, got a code 22 from my usdm p28 running an obd1 engine.
Wanted to know does this engine have a VTP sensor ?
If not i heared about tricking the ecu by splicing a wire from the vtec solenoid to the vtec pressure sensor wire. Does this solve prob ?
Originally posted by vtecjdm@Jul 16 2005, 01:44 PM K so, got a code 22 from my usdm p28 running an obd1 engine.
first, we need to know what motor you have in order for us to tell you if it has a VTEC pressure Switch or not. for all we know you could be running a DX motor with a p28.
and if you are running a d16z6, splicing the wire to the solinoid will not solve your problem. just run the wire for the pressure switch...
hellloo .. anyone out there knows if the jdm d15b vtec indeed uses a vtec pressure sensor plss ?
Might sound like a dumb question but i cant find it on mine..
Originally posted by TWISTEDIMAGE@Jul 17 2005, 07:32 PM vtp is pressure switch jdm engine has no vtp so got to honda order one. drill tap and ummmmm vtec.
