theodorcrx
Ok i search and search but the answer to my question is not answered. i have an 89 CRX HF and i want to do the mini-me swap. now i have the d16z6 head and about to get the timing belt for it. i was wondering if it'll bolt-on with my block? also i want to use my stock ecu, distributor and a custom vtec controller. Can this be done on an 89 HF.
		 i just found out found out that i will bang valves with piston if i do this swap.
 i just found out found out that i will bang valves with piston if i do this swap.   i just found out found out that i will bang valves with piston if i do this swap.
