dist. problem
  • Thread starter Thread starter 90civicdx
  • Replies Replies 1
90civicdx
when in the integra the car ran fine, when i put it in the civic i now get a code 4.
crank ang. senc. the car runs rough. does anyone know what would cause this and
what would make my dist. not work now? i did the test on it with the diff a,b,c,d,e pins i got continuity.on the f,g i got no reading.thi9s is the only code i get now , cleared the map code.
If your civic is a dx, you have to make the switch from dual point injection to multipoint injection in order to run a b-series motor. part of this swap involves altering your distributor wiring. refer to the write-up in the swap article section.
