I just found out a couple a days ago that my GSR crank, on the same one the rod bearing spun on, is crack. So I ask the guy at the machine shop what he can do for me..... he said he look into find me a new one.
He called me yesterday and said that he is unable to find a Remanufactured one or someone that has one lying around.
Now the thing is I able to find so many LS cranks with no bigg problems but GSR one are hard to find. Will the question is are LS rods and GSR rods are they the same length if I decide to use the LS crank with GSR rods and ITR pistons of course or will I the piston stick out at the top of the block. I now that the main bearing and rod bearing diameter are the same in the two cranks and I would need some ARP rod bolts to prevent streching of the rod bolts at higher RPMs.
Are some more info for everyone I have 94 GSR motor trying to rebuild it with some ITR Piston (USDM Specs) and mill down the head to rise the compression to at least 11.1 to 1 (JDM Specs). But now trying to use the LS crank because of my problem I ran into.
IF it is more work and money I need to spend or if someone has a really good GSR or Type R crank lying around for a good price email me at short_short_man@yahoo.com.
