H22a Swap Fuel ?
I recently did a H22a swap into my 95 Accord
My Question is should i have swapped out fuel pumps?
I ran my car on the dyno and it was running extremly lean
Your stock pump will be fine. The engine may have been sitting aorund for awhile, maybe you need to run some injector/fuel treatment through the system. Do you have a fuel pressure regulator? If not, you may want to get one to bump up the pressure a few psi.
No, it won't hurt anything, but if he's running an upgraded pump on a stock regulator, rail and injectors, it won't cause him to run any closer to stoich.
:werd: I feel ya' mang. That is what I meant by this whole drawn out post. The whole fuel system... :blink:
You r still the man :worthy: ! Calm yourself...have a beer B)
Peace, Theron <_<
Thanks guys but i just replaced the stock fuel pump witha performance one and i put my b&m regulator on. But my A/f Gauge still reads lean i gonna try a different gauge and see what happens
