Help 1998 ECU 1995 LS
rajb0929
I have a 1995 Special Edition , it comes with a ls motor i have just recently swapped it with a 1998 LS motor.. the tranny switches alil hard and i was just curious if there is some way i can fit that 1998 ECU into the 1995 Body .. i know one is OBD1 and 1998LS is OBD2 .. but is there anyway i can put that 1998 ECU by jumping the wires somwhere .. or is the computer getting used to the new tranny ... the 1995 ECU is getting used to the new tranny ... Thanks
:blink:
:blink:
Is this an auto?
Did you remember to top off the fluids?
Oops, my bad. Just the Accords. Manual Integra SE's came in 5-speeds.
I've said it once and I'll say it again: Screw you B-series boys. :lol:
LS doesn't have VTEC moron.
anyway- use the SE ecu... run an obd 1 dist. and injectors... an di think thats it, right?
Its auto .. so i should run the 1995 ECU and just put on 1995 Distributor and injectors on the 1998 Engine???
