Injectors
  • Thread starter Thread starter kevinbout
  • Replies Replies 6
  • Views Views 789
kevinbout
Dsm 450 injectors in a d15b7?
Will they even fit?
Will they go in without much effort?
Benifits/ bad stuff.
I don't really have much of a clue when it comes to injectors so go easy on me!.
Yes they fit. You might have to swap connectors and/or use your stock injector o-rings. You just need to run a resistor box with them(or just solder in 10-ohm resistors on the positive wires to the injectors).
Only reason to upgrade to those is if you go turbo. Otherwise, they're a waste.
Alright thanks!
So if i install them i wont feel any differance? just burning more gas?.
Are there any explanation threads on injectors or fuel rails?
The more knowledge i have the better.
Well there would be no "just popping them in" i'd put them in as proporly as possible. but it doesn't matter i'm not going to bother with them.
definately not the way to go. Stick to the 240cc stock injectors and specially for daily driven whip!
Get a fuel pressure regulator and 255 Lph Walbro fuel pump if looking for better response no need to change the injectors unless you plan on going turbo or SC.
