I'll buy the clutch, and leave it out until I burn up the stock one.
What else are you doing to the suspension? I see you're putting a subframe brace, but what about traction bars, rear LCA's, H-brace, and c-pillar braces? Shit, if you're going to do more than lower subframe and LCAs, you might as well weld in a roll-cage.
Plan on doing the bushings? I'm putting energy bushings in as soon as I wear out any of the bushings, because then I have to replace it anyway.
