Got it started, drove around a bit. Then I discovered my wastegate leaks vacuum. Then the ICM and plug wires went bad, and that pissed me off a bit, fouling the wideband o2 sensor.
Eventually though, got everything fixed up. Bought a new wastegate from speedfactory, it'll be here whenever... Until then I just deal with the horrible shreiking from it.
But, uh, this tune needs a lot of work.
But, it does make boost soon. Hits the 7psi wastegate at 3700 rpm, this ought to be a fun car.
I replaced the left rear brake cylinder, so now I have a bit more braking power, but now the right rear cylinder doesn't match pressure, lol. So I'm regretting not replacing both.
