TPS replacement Q?
dwn2low
How the heck do you replace the tps I broke mine on my b18b while removing it. I noticed there are no screws just nuby rivit like things? Please help. :worthy:
Hmm, idk, with mine on my b16 it has torx screws that I had to tighten down.
use a small file to file a slit in them,then use a small flatblade screwdriver to get them out.
EDIT: they are screws that are blunt top so nobody messes with the factory calibration. just use the method above thats how i fixed mine.
[post=520095]Quoted post[/post]​
wow..Interesting..Good Question..I always wanted to know how to remove the damn thing...
and you..wow ..Good answer..Im gonna try that...
i used a small chisel on it and a small hammer until it turned and it came right off!
