Tuning Advice
why not just fix said frayed wires to completely eliminate that as a problem? the car may not always throw a code for a problem, and the TPS can cause some weird things to happen. c'mon, n00b!
x2. Clean it up - tune it up.Then work what's left for problems. Have you done a compression test on this engine? That's something else to consider.
Aiet fine! Pullin out the solder gun and heat shrank.
x2. Clean it up - tune it up. Then work what's left for problems. Have you done a compression test on this engine? That's something else to consider.
Background:
1st gen JDM B16A all stock (10.2:1 CR vs. 10.4:1 CR gen 2)
compression test showed about 237 PSI perfectly across
I will steal my dads 02 from his mint Z6 and try it for tomorrows commute. I'm gathering up a MAP sensor and temp sensor to try as well.
