KaMaKaZiPyRo
I plan on buying a b20b, with a gsr head and a t3/t4 turbo. My power goal is anywhere from 400+whp, I want to boost up to 28psi. Also when you resleeve a motor does the bore size decrease? Here is my list of parts to get for the motor.
B20B Block
B18C1 Head
AEM Adjustable Cam Gears
Custom Exhaust
B18B Transmission
P75 ECU (this or an OBD1 GSR ECU?)
B-Series Motor Mounts
HA Sport Shift Linkage
8.5mm Spark Plugs
Integra Axles
Exedy Stage 3 Kit
ACT Prolite Flywheel
B17/B16 Throttle Cable
Hondata ECU Chip w/boost option
AEBS sleeves
CP 9:0 Pistons
Crower Rods
Crower Valves
Crower B18C Valve Springs
Crower Titanium Retainers
ARP Head Studs
Stage 2 Turbo Crower Cams
Blitz Turbo Timer
Apexi AVC-R Boost Controller
Precision SC60 Turbo
Intercooler Kit
Tial 40mm Wastegate
Turbo Manifold
3” Down pipe
Blitz BOV
AEM Fuel Rail
RC 750cc fuel injectors
Walbro 255lph Kit
B20B Block
B18C1 Head
Custom Exhaust
B18B Transmission
8.5mm Spark Plugs
Integra Axles
Exedy Stage 3 Kit
AEBS sleeves
CP 9:0 Pistons
Crower Rods
Crower Valves
ARP Head Studs
Blitz Turbo Timer
Intercooler Kit
Tial 40mm Wastegate
Turbo Manifold
3” Down pipe
Blitz BOV
AEM Fuel Rail
Walbro 255lph Kit
