It's always a good idea to do a valve lash when you pull the top end apart. The gsr cams have a different profile than the b16, so you might as well do it.
Yes u should adjust the lash intake is .007 and exhaust is .008 u allspice can take the exhaust to .009 for more power and adjust wen logos is cold have fun
i run my valve lash on the loose side in high boost cars to compensate for the valve expanding due to the extra heat. but you do lose a little lift and they are a litte noisy when cold but its a trade off
