The piping is probably Spectre too. That's why it doesn't have a nipple for the valve cover breather, because the pipe is just a generic piece. If you ever run across a cheap intake that was actually designed for your car, I'd go ahead and pick it up. Running the breather hose from the intake tube to the valve cover like stock is preferable to a breather filter...
