DarkmanA
hey there i have a 92lude with the h23A1 motor in it i have recently had a problem with it starting to bog and hesitate while i sit at a light and first start to press the gas peddle but once it gets above 3000 or 3200 rpms it runs like a champ? I have tried plugs wires, ignition coil, checked compression, fuel filter, and i cant figure it out. the distributor is new also the throttle body has been replaced, no check engine light is on and i tried jumping the wires on the eCu also to no avail. some body help me
